4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
I've run across an odd ball(I guess) type of the standard dry truck air cleaners, need help I.D.ing the thing.
The bottom of the stock one is a smooth transition as it necks down to where the clamp secures it to the carb. The odd ball I've seen is the same animal but it's neck is recessed up into the base. I saw one on ebay for sale one time said it was early Corvette but not convinced.
Most early Corvette I've seen have several styles of air cleaners and most are totally wrong. Have seen similar units on other makes of cars with same lid but the rest is different yet.
Anyone???
1946 1/2-Ton Chevy
JiMerit,
We are "flying blind" - can you post a link to a photo?
Or, email a photo to me and I will hist it.
I thought that Corvette 235s had three side-draft carburetors. I see a few photos of eBay of those three carbs sharing two air cleaners like you describe.
example 1
example 2
example 3
No sorry can't post a pic, Your first pic looks correct as far as the lid goes. Know over many years Corvette people were buying up all our truck air cleaners as originals were not to be found. There is a side by side pic of the two types I attempted to describe in Deve's photos to check out.
http://devestechnet.com/Images/Restorations/1950B/D50b00437lg.jpg
http://devestechnet.com/Images/Restorations/1950B/D50b00442lg.jpg
1946 1/2-Ton Chevy
Those two "styles" differ for the two carburetor "throat" diameters used in 47-55st.
the ones I have measure 2 5/16" same size as my old oil bath, don't have other to compare that I can get to.
The smaller one in Deve's pic is much smaller than mine.
1946 1/2-Ton Chevy
Got mine off E-Pay. I think Jim Carter Truck Parts sells these as afternarket item also.
Tim
1970 VW Beetle
Jim Carter's are for the larger throat carburetors - 1950 and later 235 and 261s (the carburetors changed to a center post for the air cleaner in 1960).
DRY ELEMENT AIR CLEANER 6 CYL 1950-1959 CHEVROLET AND GMC - ME904
Tim,
Sorry, misspoken. I have a Rochester "B" on my 216 cu.in. with the center post to attach the top and the air cleaner has the clamp for the carb.
Tim
1970 VW Beetle
Tim,
I think your 216 carburetor would have too small a diameter top to fit JC's cleaner.
I also dimly recall seeing a hard rubber "adapter-ring" that was used in the "old days" to get the newer cleaners to work on the older carburetors?
