6 members (walterhvogel, klhansen, Jman, Tom McGrath, UtahYork, Materman), 88 guests, and 2 robots.
Topics128,035
Posts1,055,557
#120377 04/19/2006 11:00 PM
Junior Member
Junior Member
problem #1 i have 2 dinged up front fenders, all steel, still on my truck, ive been wanting to take them off and bang them out, but i dont want to ruin them, and not be able to get them on, what is the best method to restore steel fenders?
problem #2 this one i doubt i could do myself, but id be willing to try, the outside driver side cab corner is minamally rusted away and i like to replace it, i have been able to locate one for under 30, would i be better taking this to a shop? if so, how much would be unreasonable to pay? i dont have deep pockets
problem #3 it needs a paint job, but id rather just get it to primer and keep it there for the time being, what is the most durable method to doing this? i dont want to end up with rust peeking through $100+ worth of primer, ive heard of rust bullet, do they make a primer like this? i thought about doing the whole truck body it.
any advice or experiance with this would be greatly appreciated.
#120378 04/19/2006 11:45 PM
Anonymous
Unregistered
Anonymous
Unregistered
#1 - Try to work the fenders while they are on the truck. This provides a stable work environment and you should be able to get to any dents to pound out from inside the wheel well. If the bottom corner is rusted out, as is typical on those fenders, it may have to be removed for that repair.
#2 - If the cab corner is "minimally" rusted you may be able to just cut a small patch instead of replacing the whole corner. Can't tell without pics. If you have the tools you can do this repair yourself. If not you can always rent a welder from Home Depot to do it with.
#3 - Without seeing a pic of the truck is hard to tell what to do on this one. If there is surface rust it must be removed and treated prior to any priming. If the pol paint is still there I would just sand it smooth and prime over it using an epoxy primer. The sandable high build primer should not be used as it will collect/absorb moisture over time and start the rust again. You might consider getting some Zero Rust in a quart and spraying the truck with that. It will last a long time, prevent further rust but will need to be scuffed and sanded prior to any future priming and painting.
Send some pics and we can see where you are starting from.
#120379 04/19/2006 11:52 PM
Junior Member
Junior Member
Anonymous
Unregistered
Anonymous
Unregistered
That truck looks pretty good. I would sand it down the paint and prime or ZR over it.
