5 members (John L., baldeagle, Joe H, panic, 1 invisible), 92 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#120373 04/19/2006 10:27 PM
Junior Member
Junior Member
I enrolled on an autobody class and carted my tailgate as my first project since it was the easiest to remove. After blasting and welding up the small holes, I cut out a good size area of the bottom roll and cut and bent new metal. When I removed the bad piece I could see that the interior had surface rust. I asked the instructor if I should do something to it. He poked it and said "Nah, looks pretty solid." But I'd just removed a sizeable piece that was swiss cheese.
So what do you think? Pour in a rust inhibitor? Or leave it be. There are drain holes on the bottom anyway...or what seem to be drain holes. I guess I could do it later, but now I can see what happens.
#120374 04/19/2006 10:37 PM
52
I don't think it would hurt anything if you decided to treat area but don't [censored] off your instructor either. Tis best to be on his good side.
Dan
#120375 04/19/2006 11:37 PM
Anonymous
Unregistered
Anonymous
Unregistered
The bottom piece you replaced was where the moisture collected over time. The other inside surfaces should not be a problem if the metal is still solid. I would not worry too much about it.
#120376 05/02/2006 8:49 PM
Junior Member
Junior Member
Thanks for the opinions. I've patched all the "swiss". But the drain holes will allow access if I decide to take precautions.
