1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | I enrolled on an autobody class and carted my tailgate as my first project since it was the easiest to remove. After blasting and welding up the small holes, I cut out a good size area of the bottom roll and cut and bent new metal. When I removed the bad piece I could see that the interior had surface rust. I asked the instructor if I should do something to it. He poked it and said "Nah, looks pretty solid." But I'd just removed a sizeable piece that was swiss cheese. So what do you think? Pour in a rust inhibitor? Or leave it be. There are drain holes on the bottom anyway...or what seem to be drain holes. I guess I could do it later, but now I can see what happens. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | 52 I don't think it would hurt anything if you decided to treat area but don't [censored] off your instructor either. Tis best to be on his good side.
Dan | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The bottom piece you replaced was where the moisture collected over time. The other inside surfaces should not be a problem if the metal is still solid. I would not worry too much about it. | | | | | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | Thanks for the opinions. I've patched all the "swiss". But the drain holes will allow access if I decide to take precautions. | | |
