1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#120369 04/19/2006 12:52 PM
well i ran into some cash and ran into a 52 in grand forks ,, complete runnining fairly new paint and when i went to see it the dash was cracked from one end to the other... what caused this? and will the rest of the truck follow?
every thing else is fine,3 window 3/4 ton ,tonneau cover. nice wood box,nedded nothing but tlc, 6 cyl with 4 on the floor, 4500.00 beans. :confused:
#120370 04/19/2006 8:15 PM
When you say the dash was cracked- do you mean the paint is cracked or the sheet metal?
If it is the paint, could be that someone used a type of paint on top of the stock paint that doesn't combine too well. I sprayed some rims with a rattle can and it looked great until it dried, then it cracked- Turned out the paints weren't compatible. Solution: Sand it/scuff it, use the right primer and then paint on top.
How 'bout a picture?
#120371 04/19/2006 8:33 PM
well i have no pics but i think it was a home made restoration, didn't spend too much time looking at it but it's stuck in my head and won't go away.. definatly cheaper than continuing on my 58,, grin
#120372 04/20/2006 2:55 AM
From what you say, sounds like a good price.
NM51 has a good point. So was it sheetmetal? just paint? or body filler?...or just stuck in your head? :p
anyways, good luck!
Colin
