| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | well i ran into some cash and ran into a 52 in grand forks ,, complete runnining fairly new paint and when i went to see it the dash was cracked from one end to the other... what caused this? and will the rest of the truck follow? every thing else is fine,3 window 3/4 ton ,tonneau cover. nice wood box,nedded nothing but tlc, 6 cyl with 4 on the floor, 4500.00 beans. :confused: | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | When you say the dash was cracked- do you mean the paint is cracked or the sheet metal?
If it is the paint, could be that someone used a type of paint on top of the stock paint that doesn't combine too well. I sprayed some rims with a rattle can and it looked great until it dried, then it cracked- Turned out the paints weren't compatible. Solution: Sand it/scuff it, use the right primer and then paint on top.
How 'bout a picture?
| | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | well i have no pics but i think it was a home made restoration, didn't spend too much time looking at it but it's stuck in my head and won't go away.. definatly cheaper than continuing on my 58,,  | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | From what you say, sounds like a good price.
NM51 has a good point. So was it sheetmetal? just paint? or body filler?...or just stuck in your head? :p
anyways, good luck!
Colin | | |
