1 members (delky),
86
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Bolters, have a 59 Chevy 1/2 ton...when purchased had separate turn signals on a non original bed... Original owner had cobbled in trailer wiring harness as well.... So now. I'm wanting to convert to single tail light rear BUT....running lights workin fine, brake lights yes ... Now here's the But part, turn signals yes as long as there not joined to the brake wire for the single tail light, when they are joined no turn signal just brake, even the flasher stopsâ€¼ï¸ Could you gentlemen pls point me a direction for a wiring tip without going back to the dual light setup...there is not an add-on turn signal on the column to try the tech tip listed..txs | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here's the factory wiring for use with dual tail lights - you're maybe missing the "crossover" wires at bottom center, which weren't used with the separate turn lights, which is seen bottom of this pageBill | | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Txs so much...will try to dig deeper....so being electrically declined it seemed with all the correct wires I could just bundle them together and it would just work!!! I will explore. txs again Steve | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | To use the same lighting unit for both brake and turn signal you must have a switch designed for such. | | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Signal sw Mr Cletis? Front end uses running lights as blinkers so I assume that sw would work for signals rear too? Or is it brake light sw? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You say there is not an add-on turn signal on the column. Just what kind of switch do you have? | | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Sorry for not being clear...just "what I assume is a stock column and signal indicator " not "what I assume is an aftermarket unit as pictured in your tech tips | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should be able to wring it out then using the diagram Bill posted. | | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Ok, will carry on then, thank you both | | |
