0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
Z
Z Offline
Is there a torque specification for the bolts on the pressure plate on my 1/2 ton truck ???
Could not find one in the service manual.
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Should be 3/8" grade 8 bolts. Somewhere between 38 and 45 ft/lbs would be a safe range. You should be able to 'feel' when they're right. Make sure to use grade 8 lock washer also.
1950 4100 - unrestored and driven weekly for almost no reason at all.
A two-bolt-pair "retainer plate" (lock) that was thinner than most lock washers was used early (at least thriugh 1954) stovebolt flywheels, and the bolt had a thinner head than on a "standard" hex head bolt.
This thin-head bolt and star washer produces/results-in a thin profile.
Those two-hole lock-plates were used through at least 1954. After that, the same thin-headed bolt was continued, but it looks like a thin lock washer became the standard bolt-lock.
Zoegrant, are you referring to the bolts that attach the pressure plate TO the flywheel? If so, then mechanic58 is dead on.
The picture Tim shows appears to be what attaches the flywheel TO the crank. although the same design may very well have been used on the pressure plate also.
My flywheel (on a 51 3100) did have the two-hole lock plates on it that Tim referenced, which I will go back with. But we have used external tooth lock washers, and red Loctite, many times on these.
Mike
Mike
1951 3100 5 window
1950 Chevrolet Service News
Page 1 TORQUE SPECIFICATIONS March 1950
Page 2 Engine (All models)
Flywheel Bolts (All models including P.G. Automatic transmission) 50-65 Ft. Lbs. Torque
Page 3 Transmission (conventional)
Clutch Cover to Flywheel Attaching Bolts 25-30 Ft. Lbs. Torque
Note: Correction - Torque Specifications August 1950
Universal Joint yoke attaching bolt were 25-30 Ft. Lbs. but were changed to 15-20 Ft. Lbs. Torque
Read Correction (Scroll down)
Source: 1950 Chevrolet Service News
What year is your truck?
Z
Z Offline
My truck is a 1953. ..
The info supplied by all is extremely helpful...
Just to clarify my previous post.
The torque spec. below:
The above spec. is for the one bolt Illustration, Group # 4.405 that holds the front yoke to the main transmission output shaft. (click picture to zoom)
The four U-Joint bolts or cap screws Illustration, Group # 5.586 are tightened to 25-30 ft.lbs.Torque
Read number 3. under Assembly
In summary:
The four U-Joint bolts or cap screws, 25-30 ft.lbs. Torque
The one U-Joint front yoke attaching bolt, 15-20 Ft. Lbs. Torque
Don't forget the two U-Joint bolts/cap screws lock plates.
