1 members (moparguy),
80
0
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 12 New Guy | | New Guy Joined: Dec 2016 Posts: 12 | 1961 Apache, I see there are four threaded holes on the top of the radiator support bracket. I also see four threaded holes on the top of the grille support where the hood latch is mounted. Two of these hole are located on the inside corners of the front fenders. Can anyone tell me what these are used for? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Pictures would help. But 2 holes IVO of the hood latch bracket might be for a radiator holddown bracket. I have seen some rad support with those holes and some without. I have not researched why some would include the holddown bracket. My 62 w/283 came without. A 66 w/250 came with. I dont have a good sense of where the other 2 fall out. | | | | | Joined: Dec 2016 Posts: 12 New Guy | | New Guy Joined: Dec 2016 Posts: 12 | Ok, I figured it out. There are two sheetmetal pieces that attach to the grille support and the radiator support on either side of the hood latch. Now that I know this it explains why I couldn't figure out how to attach the rubber hood bumpers | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | ...and thank you, Hambone, for the response.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Pictures would help. But 2 holes IVO of the hood latch bracket might be for a radiator holddown bracket. I have seen some rad support with those holes and some without. I have not researched why some would include the holddown bracket. My 62 w/283 came without. A 66 w/250 came with. I dont have a good sense of where the other 2 fall out. In 1963 they changed the way the radiator mounted. They removed the side mounts and went to a couple of U-shaped brackets on the bottom with rubber bushings and a single mount on top. | | |
