| | | Forums66 Topics128,165 Posts1,057,011 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 5 New Guy | | New Guy Joined: Nov 2016 Posts: 5 | hey guys. I have a motorhome diff im putting in my coe. at first i spun the tire and figured just over 2 turns. didnt seem right. i checked my other parts diff. same thing. they are both p37 class a 1 ton diffs (14 bolt). so i cleaned the axle and got the stampings KMM G 2 ? 67 i pulled the cover and the ring gear is clearly stamped 209 1 CA 3977334 10 41 8 73 has anyone heard of such a beast and what would one do for a speedo gear?
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The 10 and 41 in that number sequence is going to be the tooth count, for a 4.10:1 ratio. The 8 73 should be the date of manufacture. Try counting the teeth instead of trying to interpret the stamped numbers. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If only one wheel turned in your counting turns method it'll seem like ratio is 2X as fast as it actually is. Again you're looking at 4:10. | | |
