1 members (1 invisible),
100
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,394 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | My shop is a metal building and I cannot get a cell phone signal. The boss keeps accusing me of ignoring her calls and messages. Some of you will say....not so bad....but does anyone have any experience with a booster or such before I embark on research?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Have you looked into a different cell provider? Have someone with a different provider come inside of your shop and see if it works.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | That's a pretty common problem, especially if you have a metal building. My shed has what I call "hot zones," places you get signal, places you don't.
I've looked into some signal boosters, where you put an antenna outside and have a repeater inside. Not for sure how well they work. Not for sure if I want to go through the trouble either. | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I use this Dual Band booster at a lake house. Metal roof and down in a valley at a lake. Outside if I hold my cell phone up in the air I get a good signal. Inside the house, nothing. With this booster I get 4-5 bars. Dual-band device works with 800/1900 MHz frequencies from all major carriers--AT&T, Sprint, T-Mobile, Verizon, Alltel, Cricket, and more (not compatible with Nextel). We got the dual band, a little more expensive, because I have ATT and my brother has T-Mobile. They use different technologies/bands. I am very happy with the results. As stated above, you place an antenna outside and run a cable to the unit inside. It also boost my signal when out in the yard. I had one for about 2-3 years and I think it was fried by lightning. I did not hesitate to spend the money on a replacement. I have had the current one for about 5 years. You can disconnect it when you are not there to reduce that risk. About $200. Link to unit on Amazon
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Perfect. That's what I was looking for Dave. Many thanks.
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | My shop is a metal building and I cannot get a cell phone signal. The boss keeps accusing me of ignoring her calls and messages. Some of you will say....not so bad.... I sure will! Just think - your wife can't get hold of you either when you're trying to concentrate on what you're doing.  Once in a while I can't even get a signal in my garage which isn't metal. Does it depend on local "traffic"? | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Have a similar problem in the house as well as the shop. My shop doubles as my office and warehouse, so missing calls is NOT AN OPTION! I had been running 2 microcells for ATT. Run off internet. Basically turn phone into VOIP. But now my phone all have wifi calling capacity. So I just use that. I have strong wifi in both locations. Besides the router/wifi for the shop, and if your phone has that capacity, should be the ticket without any specialized equipment. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | What can I do to my shop to block cell service?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What can I do to my shop to block cell service? Turn off your cell phone? Leave your cell phone in the house? | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I have not confirmed but I was told the other day that AT&T and other vendors will give you a repeater? | | |
