| | | Forums66 Topics128,034 Posts1,055,440 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | I was taking out/cleaning out my window regulator assembly and, noticed surface rust from rain run-off on the inside of the door panels. :rolleyes: Would spraying zero rust(or like products) help?
jcf
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | At autozone they sell a Duplicolor rust converter in 1 pint plastic jars for about $5.00, its at the paint and body section. I've used that stuff and it works nicely! They also sell a rust converting primer in rattle cans, also duplicolor. Either one is what I would use after wirebrushing and sanding. Then check to make sure your seals are all good.
