2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 22 | I have a 235 in my 51 and the original torque tube, and 4:11 gearing. Im not wanting a streetrod as I bought this truck because its a stovebolt and period looking.
like everyone else Im wanting to change to a 3:55 gear. the 3:55 install kit and the ring n pinion are over $900 combined and I am not comfortable doing the swap myself based on what Im reading needs to be done.THIS IS A BIG JOB! PARTS AND LABOR IM LOOKING BETWEEN 1700 AND 1900 INSTALLED.
I am curious what my options are. I do not want to run a T5 my origianl trans 3speed on column works great and shifts like butter.
I do not want an S10 frame if I did I would have bought anS10 truck.
I have heard of using early 50's powerglide car rears due to the factory 3:55 gear and torque tube on 46 and older truck but what are the alternatives for the AD trucks. thanks
It aint a hobby it's a lifestyle! LIFERS C.C.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you figure out a less expensive alternative, let us know. An alternative that includes new internals, seals, and bearings and labor. Luckily, I saved on labor - I had a friend with me - he knew modern rear ends. We figured out the old torque-tube and it runs like a charm (check the Stovebolt Tech Tip by Sweet). I bought the tools I needed (run-out gauge and magnetic base holder?) from Harbor Freight. Prussian Blue "grease" is readily available (Permatex). | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | You can buy taller tires. What are you running now?
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | passing thru,
There is someone on Ebay selling the rear ends with the replacement gearing installed as John Millman, Denny Graham and Chris Sweet and Barry Charon said in their missive. They mention "not including" the brake drums" I cannot find them at this point. I'll guess someone bought them or they timed out.
Julian
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | There are several obstacles to overcome with the car to truck swap: Different spring spacing 5 lug axle shafts that do not swap with the truck 6 lug axles Different torque tube and driveshaft length Possibly different U joint
By the time you get the car axle adapted, you'll have a great deal of money invested in a non-original item with virtually no source for repair parts if it gives trouble later. Do your homework before beginning that project. Where in Georgia are you? I'm in middle Tennessee near I-65 and the Ala/Tenn state line. I have a complete 1952 Powerglide rear axle assembly stashed away. Jerry
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | You can buy taller tires. What are you running now? A Task Force '55-'59 3.90 rear differential or the entire axle for that matter will give you easy 65-70 mph w/o taxing the engine. I routinely go over 2000 ft passes in 3rd gear with my 3.90 rear in a '49 1/2 ton. The engine is a '56 235. I've bought 3.90 rears for $125, 20 years ago and as recently as last year.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What Cosmo said 110%. Get a donor truck 6 lug diff 55-72 with what ratio you like. Get a driveshaft with it and get it modified. Get rid of Torque tube. Go open. Then if anything goes wrong, the parts are easier to find, install and more reliable. Way cheaper and DIY. Just study google and here for what diff has near WMS-WMS and what it takes at tranny. Lots have done it, lots of info. You can buy 10 diffs for that money. If Cosmo says 3.90 works, he knows. I would go higher, which is a lower number. BTW I have a nice 1953 AMI 120E.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Thanks Bart. Here in the Piedmont (rolling foothills) inclusive of 2000 ft passes to get to another valley the 3.90 happens to work well. You live in GA, so consider the terrain where you will be doing most of your driving and the speed with which you would like to travel. I'm with Bart's advice about getting out of the torque tube for the main reason of the availability of overdrive transmissions. I have a '69 3sp+od with 3 on the tree and love it! Prior to this transmission I had the earlier generation 3 sp+od the series with the non-synchro first gear. I ran that transmission for near 15 years, 3 on the tree, loved the capability.
You can have what you desire, column shift and good drivability, even without an overdrive..
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Other options: In 54 trucks had open drive shafts with a drop out diff. All the way to 62. 47-53 has a Torque Tube drop out. You can swap guts/drop out and make a TT rear end into a open. It's a bit of a fab intensive job but not real technical. That gives you ratio opportunities, stock diff/width, No brake line or ebrake cable problems. Basically: Take off leaf spring to axle tube "clamp" and weld on a spring perch on bottom.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Other options: In 54 trucks had open drive shafts with a drop out diff. All the way to 62. 47-53 has a Torque Tube drop out. . . . 1954 trucks larger than the 3100s had open drive shafts. 1954 3100s had enclosed driveshafts (and 3.90 rear ends). | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Doesn't a 51 3 speed have the oddball small transmission to bellhousing bolt pattern? If he's going to swap to an open driveline he's going to need to change everything from the engine back, including the bellhousing. Looking at things from that perspective, the 3.55 aftermarket gearset begins to look a lot more budget-friendly. Granted, us old geezers who aren't intimidated by setting up rear end gearing are getting a little scarce, but it's not impossible to do. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks TC, I'm off a year or two. 55.1 have open on 1/2? or was it not until 55.2? Anyway Jerry and passinthru: I did my 60 diff awhile back. I don't know yet if I did a good job or not. I think so. This poster seems like not ready to try. It took me till now to get the nerve. In my case I had to buy: 1. Torque wrench that went to 250 lbs. I only had a 150 2. Inch pound torque wrench 3. Dial indicator and magnetic stand 4. Build a yoke holder 5. 20 T press 6. Two sets of pinion bearings 7. Two sets of carrier bearings 8. Ring and pinion gears 9. Shim set/yellow pattern compound 10. One set Spyder gears 11. New pinion nut 12. One set wheel bearings and retainers 13. Seals 14. Gaskets 15. Grease and oil
And: Heaving lifting, took off diff and put on bench Drill and split old wheel brg retainer Old parts and bolts put up a fight and must cut off/heated/etc. sometimes. I'll bet AD parts will be harder to find than my era. Room to work/high bench preferred Lots of tools Total cost of parts and tools= cheaper than a shop and I keep all the tools/equipment I bought. I tried for 4 months to find a donor GMC Dana 44 in 3.92 to match front diff. No dice.
It is a chore. I have a lot of mechanical experience, tools, read up on the technique, and finally, the patients to get it right after many tries. It ain't rocket science but it ain't changing your oil either. I don't know if AD is easier and needs less equipment or not. Whatever he has to do up front is just bolting donor parts, I assume. I'm sure several guys will chime in who have done this and it's probably in the search. I'm basing my advice in this case on the $1900 and the poster not comfortable doing it. Some cases I would encourage a Stovebolter to go for it DIY and learn. Not in this case with a diff gear change unless somehow there is no need for all the backlash/preload/press off, press on/tooth pattern check procedures. Even though a person could swap drop outs, that's a lot of work and some welding. I would still recommend a open drive line. A good, patient, searcher/scrounger/negotiator could get the parts for $500-$600 total if in a populated area or lucky enough to be near one of those good old wrecking yards. Now almost all gone. So that's my story. Good luck, from "Justhanginginthere"
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | bartamos,
1955-1st was the first 1/2-ton (31xx series) year/model with open drive shaft.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thank you, correction noted.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Bart, did your kit come with a 'crush sleeve'?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No, there is no crush sleeve on Dana 44. They use shims only. If you buy two sets of bearings, you grind one set to a light press fit and use them on and off until finished shimming for preloads, backlash, pattern and then press/drive the other set on. I did mine because I had a broken pinion, not to change ratio.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Doesn't a 51 3 speed have the oddball small transmission to bellhousing bolt pattern? If he's going to swap to an open driveline he's going to need to change everything from the engine back, including the bellhousing. Looking at things from that perspective, the 3.55 aftermarket gearset begins to look a lot more budget-friendly. Granted, us old geezers who aren't intimidated by setting up rear end gearing are getting a little scarce, but it's not impossible to do. Jerry Jerry, I have a '50 3100 which at one time or another, I have had a torque tube 3-speed, a 66 Saginaw 3-speed, and now a T-5 bolted to the original bell housing. The bolt pattern was the same as the original bell housing on all three transmissions. I am assuming it would be the same fr a '51. Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The 4 bolt Chevy trans pattern is pretty much standardized with a few exceptions., It is the bell housing to motor and starter mounting/flywheel size problems that most encounter. Not relevant in this case. The pattern fits Muncie, Saginaw, Stewart and others. This is just one example why Chevys are used so much in all forms of swaps. Everything fits everything, almost. Fords are not like that at all. You can find Chevy built motors in trucks, cars, boats, motorcycles, military vehicles and planes. (Pratt and Whitney radial engines for bombers and cargo. Every part built and assembled at Tonawanda. WWII.)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In 1948 Chevrolet trucks started this transmission bolt pattern. In 1955 this same pattern was started in passenger cars. This bolt pattern was used for as long as I have knowledge of, may still be used. It is also the same bolt pattern the T5 trans uses.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | OK- - - -I have several torque tube transmissions and a couple of bellhousings with the smaller bolt pattern- - - - -obviously passenger car stuff! Good to know when the change was made! Jerry
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2017 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 22 | What Cosmo said 110%. Get a donor truck 6 lug diff 55-72 with what ratio you like. Get a driveshaft with it and get it modified. Get rid of Torque tube. Go open. Then if anything goes wrong, the parts are easier to find, install and more reliable. Way cheaper and DIY. Just study google and here for what diff has near WMS-WMS and what it takes at tranny. Lots have done it, lots of info. You can buy 10 diffs for that money. If Cosmo says 3.90 works, he knows. I would go higher, which is a lower number. BTW I have a nice 1953 AMI 120E. are the 55-59 rear axles the right with etc? what else is needed to make this setup work? does the trans have to be modified in any way? does a 3:90 rear end really make that much of a difference? vs a factory 4:11?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It's a Jukebox. 1953 AMI 120 songs. I thought you were hip to Jukeboxes. I read your profile. Never mind. Not important. As far as 55-59 diff, you will have to do your homework. Widths are all online. Measure yours and see what comes close. 55-59 is pretty close. If I was switching over to open, I would try to go a little newer than that. 12 Bolts are good and come in 3.73 which is the perfect ratio for acceleration and Hiway mix. Your truck width will be in the 60" range. Wheel Mounting Surface to WMS. Also regarding what affect ratios have: there are "fill-in" calculation formulas and charts on line, to see various combinations for speed, mileage, acceleration, etc. As in any proposed modification, you have to search the internet. Stovebolt is a good place to search and to ask those questions about what is involved/transmission/what fits what. Members who know what parts to get will advise. I think 52Carl has a very good grasp of this. Lots of "car" 5 lugs rears but not too many 6 on 5.5 lug patterns from a truck. Not to over simplify but the basics are: Make sure you know what components for your motor or your bell housing to use. Work your way back to diff. Buy the parts. That always helps to see the way forward. It gives you things to measure and contemplate. Sell the old diff and other parts to recoup funds. Rip out the old and put in the new. In the rear, you are going from leaf to leaf. That's a matter of spring perches being welded on and tightening the U-bolts. Hook up brake line and Ebrake cable. The line is easy but the Ebrake may take some thinking. When rear end is installed and it's yoke is "aimed" correctly for pinion angle, and new or old tranny is mounted, measure and have a drive shaft made or modified. It's planned out just like any other "home" project as I see you are aware. I found This in our search function. I have found that sometimes an automatic trans is very nice. Easier to install, no clutch, plenty of acceleration and overdrive. You do lose that manly tactile shifting feel however.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2017 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 22 | bartamos, yeah im into jukeboxes I have a 58 Wurlitzer 2204 I love the AMI continental looks like r2 d2, ever seen one? you through me off abit I was thinkin truck parts hahaha wasnt even thinking about AMI jukes
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I've seen the Continental in Photos only. Pretty neat. Yours is a nice one. Any visible 45 box is nice to have.
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I'm hoping to do the same thing on my '53. I want to find a later truck rear end w/open DL and 3-speed to replace the existing 3-speed since it's only made for the enclosed DL.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | |
