5 members (Peggy M, Uncles51, JW51, Millenimech, Chip O), 61 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#120253 04/11/2006 2:02 PM
Junior Member
Junior Member
I hope you folks can help me out. I have the cab off my 66 and I'm ready to start fixing my body cancer. I have purchased replacement rockers, inner rockers, and floor supports and floor. Does anyone have detailed pictures of the lower front and rear hinge pillar area behind the rocker? I have the factory assembly manual but it doesnt show those areas very clear. Also, does anyone have any good ideas on how to fix those areas since you can't get patch panels for 60 - 66 hinge pillars.
#120254 04/11/2006 10:30 PM
That is a pretty difficult project. You may want to consider finding a donor cab to get these parts from, or just find a better cab.
Paint & Body Shop moderator
#120255 04/11/2006 11:15 PM
I used 67-72 lower door hinge repair. I cut off the vast majority of them but it was easier than fabbing from scratch,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#120256 04/13/2006 2:58 PM
Junior Member
Junior Member
Brian,,can you give me a more detailed description of how you used the 67 hinge panels?
#120257 04/13/2006 3:13 PM
I wish I had taken pics, but the 67-72 hinge pillar is similar, except the fender attachment is one piece w/the pillar, this was cut off(I kept the separate bolt-on fender attachment)had to redrill holes for said fender bracket. here is a poor pic, if yo look hard you can see pillar patch just above rocker mounting, brian only pic I have
