| | | Forums66 Topics128,162 Posts1,056,945 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I was thinking of putting one of those roll on Bed Liners on my 60' short Step Side.
I don't have the time to do a frame off restoration right now, so I just want to fix it up as a weekend runner that will see normal use as a workhorse for the weekend warrior.
If I use a roll on bed liner on the sides, front panel and tailgate, can it be blasted off in the future if I choose to performa frame off restoration or is it considered permanent?
What do you think?
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | That stuff is pretty tough. It may be that if you heat (torch) it and scrape when warm it will come off in a mess. Nevertheless, its what I plan on putting on my bed. | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Thanks tlorber..
I think I might pass on it since I might do a complete frame off resto in the future if the kids get into it. If it was removeable by sandblasting, I might think about using it but heating it would probably make too much mess and I doult it would all come off.
I do plan on using it on my 1965 c30 because that old bird was never meant to be a show truck (new or old). I might even use it on the floor and underneath the cab!
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | FYI to anyone considering this... if you're going to do it make sure you use the good stuff... like the saying goes "You get what you pay for". I used the cheap stuff and followed the "for best results" directions (apply 3 coats) after proper cleaning... yeah it looks GREAT til something actually touches it then it scrapes right off. I think next time I'll just bite the bullet and have it done professionally. Best of luck
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
| | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | What is a "good" brand of the roll on stuff to buy, & where can it be bought? thanks | | |
