| | | Forums66 Topics128,157 Posts1,056,878 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I pulled the valve cover on my 261 and noticed a broken oiling tube. I bought this motor years ago and I've never ran it. My question is: Do I need to find a replacement tube / repair it or will it be ok as is? Thanks, Cory | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year 261?
There were different styles of "oiling tubes" between 1954 and 1963.
"Do I need to find a replacement tube / repair it or will it be ok as is?" Run your engine with the valve cover off. If oil comes out of the rocker arms, you are OK. If no oil comes out of the rocker arms, buy a replacement tube (eBay - make sure it looks like your tube).
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Tim, Thanks for the quick reply. I'm not sure the year of the head casting number 3836848 GM29 but, the block is 1958 Canadian. Casting # 3733813
I'll do an engine run and check it out.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Cory, I hesitate to advise on what was used in which years on Canadian trucks. Here is a page with different styles of connectors/oilers used on USA trucks. That might help you find what you need (in eBay, perhaps). Please let us know how this works out for you. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Cory, not to worry...just needs a tweak. Prior to 1959, the oil tubes looped around and returned the excess oil to the sump through the head. Starting in 1959, the oil tubes were pinched off to force more oil through the rocker tubes.
Many mechanics would adjust the pre'59 tubes by cutting off the return loop and pinching them off to force more oil to the rocker tubes. It was very common, so much so that it seems that you can find more pinched off ones in salvage yards instead of intact ones.
Yours is halfway modified. The return loop has been cut (broken) off, but the tube wasn't pinched off. Simply remove it, stick the cut off end in a vice and crimp it shut. Then you'll be good to go with all of the oil being forced through the rocker tubes.
Matt | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | If it is a Canadian Pontiac motor, 55 to 62, the 848 head is what it came stock with and it would have hydraulic lifters, if you search Canadian Pontiac 261 you will have better luck finding info. I have one and the tube is pinched off | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | justmike- that is the first time that I have heard that... did the factory do this to increase compression? Interesting
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I have a NOS 261 cam that has a label on the box that says that it is for a 261 with hydraulic lifters and a Powerglide transmission. I picked it up at a swap meet. I thought it was odd thinking that the 261 was only available in larger trucks in the USA and I doubted if any of those came with Powerglides. Must have been made for a Canadian 261? I know some of the Chevy cars in the USA with 235's and Powerglides had hydraulic lifters, so since the 261's in Canada were in Pontiacs, maybe the hydraulic lifters were for the same reason?
If anyone needs a hydraulic lifter 261cam, send me a PM. I've only seen solid lifter ones available through the various parts suppliers. I won't be using it.
Matt | | |
