| | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 14 New Guy | | New Guy Joined: Jan 2017 Posts: 14 | I am looking for a 235 in the denver area. Any help would be appreciated... Thanks. Houdini | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | I just met a guy out towards Peyton that said he has several good running 235s. He owns a junk yard out there. I have a '54 235 block that I would give you if you could use it.
Wayne S. Colorado Springs, CO
| | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Have a 235 out in the shop if you still need one...T K | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | I just thought of something. We are not supposed to be buying and selling in the forums, so as long as you are just "looking", I think it will be ok. Also, since there is not much going on here, at least there is a little chatter going on.
Did you put a post in the "Parts Wanted" area too?
