7 members (ShopRag, KEVINSKI, Peggy M, Otto Skorzeny, Hotrod Lincoln, 1955 1 Series, 69Cuda), 152 guests, and 4 robots.
Topics128,267
Posts1,058,373
Members48,485
#120175 04/02/2006 3:49 AM
will it work or not?I have blasted a couple of doors and washed them to stabalize rust till i prime. thought just hit me so i ask. tom
I don't suffer from insanity, I enjoy every minute of it!
Anonymous
Unregistered
Anonymous
Unregistered
If you have treated the metal with a rust converter or other acid product you should use a cleaner/degreeaser before spraying your epoxy. I also hit the clean metal areas with the DA sander using 80 or 120 grit paper to remove any film/residue.
