3 members (Uncles51, baldeagle, Shaffer's1950), 93 guests, and 1 robot.
Topics128,026
Posts1,055,408
Members48,422
#1201530 01/26/2017 10:35 AM
Quick question, my 50 chevy 235 oil bath keeps running dry after 50 miles or so. Many tell me that should not happen yet I'm at a lost as to what causes it
Dan
DJRoy #1201618 01/26/2017 9:32 PM
Riding in the Passing Lane
If its not obviously leaking out, the engine is sucking it out. The top may be too far into the reservoir. There is a thick rubber gasket that goes in the center between the top & bottom. It may be missing. You may e using too thin of oil. use 15w40 or 20w50.
1972 Chevy c10 Cheyenne Super
that's interesting, cause I don't have that rubber gasket, can it be purchased?
DJRoy #1201713 01/27/2017 2:24 PM
Ex Hall Monitor
Ex Hall Monitor
Mine functioned OK but I feel a modern paper filter provides better filtration. Swapping to one could be the answer. I did that with my '38. Your '50 filter may not all the swap, I'm not familiar with how it's constructed. Here's a good resource for finding a filter.
DJRoy #1201735 01/27/2017 4:36 PM
I don't know were you would purchase one but it can be made from a little strip of rubber. It is about 1/8 in. thick.
DJRoy #1201738 01/27/2017 4:52 PM
I use a fram CA148 on my 216. Fits great. If you think you want to change I'd take the filter housing with you to your parts store to be sure the fit satisfies you.
Ed
