3 members (78buckshot, Ridgeback, 1 invisible),
109
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | Sorry, I also should have said the truck is early 1949 1/2 ton.chevy.Thanks,Ron. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but it would be better if you say it in the original post - just click the [img] http://www.stovebolt.com/bboard/ubb//edit_ubb6.gif[/img] edit icon above your post here, and when the edit form comes up, check the "delete post" box and then the edit post button, which will disappear this one - you can then go to your other post and edit it to include the info Bill | | |
