1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
Junior Member
Junior Member
Having problem installing trim outside of windshield,new glass and weather strip,weather strip has grove to accept trim(delux model),trim is in good shape with small turn-in at bottom of blade that goes into rubber. Local expert said "have to remove windshield to install s.s trim" 2nd expert says"maybe you can work it in using MO-Jo (hand cleaner)and plastic knife as tool". Any input would be appreciated.Thanks,Ron. P.S-glass has been installed about 7 months.
What year truck?
First guy is right.
Yep. First guy is right. Second guy is a bit nuts.
1954 GMC De Luxe COE
More than a bit.
Where can you get the S.S. trim for the rubber on a deluxe '54? I need all of it if I go that route.
1954 custom 1-ton (1 of a kind)
The trim or the rubber?
Trim - eBay
Rubber - Steele
Make sure the trim has the 4 little connectors before you buy.
