7 members (Donf, King Kielbasa, jmoore, Gdads51, cmayna, 2-Ton, 1 invisible),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | Having problem installing trim outside of windshield,new glass and weather strip,weather strip has grove to accept trim(delux model),trim is in good shape with small turn-in at bottom of blade that goes into rubber. Local expert said "have to remove windshield to install s.s trim" 2nd expert says"maybe you can work it in using MO-Jo (hand cleaner)and plastic knife as tool". Any input would be appreciated.Thanks,Ron. P.S-glass has been installed about 7 months. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Yep. First guy is right. Second guy is a bit nuts. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | | | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | Where can you get the S.S. trim for the rubber on a deluxe '54? I need all of it if I go that route.
1954 custom 1-ton (1 of a kind) | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The trim or the rubber?
Trim - eBay Rubber - Steele
Make sure the trim has the 4 little connectors before you buy. | | |
