7 members (Scott, 55shaker, Hotrod Lincoln, wilbur53, Wayne67vert, 2 invisible), 67 guests, and 3 robots.
Topics128,205
Posts1,057,430
Members48,471
Hello All,
Can anyone help me understand the original mounting of the voltage regulator and fuse/horn relay to the firewall. I feel stupid asking, but is there special hardware or a particular size of screw? I thought 1/4-20s would work, but the holes in my firewall are too small for them.
Nico
The two screws in this photo attach the cover to the base.
There are 2 "bushing" holders on the left side and an opening for a bushing on the right side - I think the original bushings were pieces of rubber with a washer on the top of the rubber.
3 screws are used to go through the three opening/bushings.
bushings like the ones in figures 5 & 6
I had a hard time finding those rubber bushings a few years ago. I'll see if I can find a source.
Thanks Tim, I have the bushings, but I am curious about the 3 screws. 1/4-20 screws fit the bushings very well, but they won't go through the firewall without me enlarging the holes. Should I be using 10-32s?
Might as well give it a try.
If I remember, I'll check mine tomorrow.
Hey Tim, the size 10 screws fit like a glove!
Congratulations
Thanks, for the report, Nico
