2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | While replacing my front brake shoes on my 58 I had one of the balls fall out of my front outer bearing. I thought no big deal until I got to the parts counter. Finally advance auto ordered one for me and when it arrived it had a plastic carrier for the balls to ride inside. The bearing was a B 67. Has anyone used this type of bearing and had long lasting results. I'm not at ease with it yet. Can the torque be the same 30 ft. pounds as the all metal bearings? It's in and I moved the truck around the yard but have not road tested it yet. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | All the plastic does is keep the balls spaced evenly- - - -it carries no load. As long as the bearing is packed and torqued properly, it doesn't matter what material the spacer is, and the assembly and torque procedures should be identical. I've used that type of bearing often with no issues. Jerry
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Thanks, I feel a lot better hearing from someone who has used them before. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 6571, I know the ball bearings have worked just fine for many years and still can...however, we're getting gouged on price because they are they are old. The inside bearing on my 52 panel was $53.I bought a complete set with seals to switch my panel to rollers for $100 bucks. I believe the same kit works up to 1959. Advance Auto gets them from Rare Parts and you pay the premium. Check around. If you want to change them all I can round up the part number for the complete set. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Hey Alvin, is converting to roller bearings just a matter of changing out the races, bearings, and seals?
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I only changed the drivers side outer. Send me the part numbers, the next time I have the hubs off I will change mine over to roller. Thanks Alvin | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Carl, yes. 6571: I always switch to tapered rollers. The kit 47-59 includes inner and outer tapered roller bearings, race (also called cup and cone) and seals for less than $100. Albeit 58 is a lucky year because the stock ball bearings and seals seem to be cheaper than pre 58...but not cheaper than the kit. Just one vendor exampleI have also used a different kit made for disc conversion. The above kit is supplied to Speedway, and many other vendors, by CPP. The price is fixed. There seems to be several sizes/designs for 58 1/2T front bearings? Don't know why but double check ID's and OD's of kit bearings to your bearings. Scroll down for B67 dimensions.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 6571, I checked and I got mine from the Truck Shop in Concord, N.C. The kit number is 47-09216 for $99. http://www.truckandcarshop.com/trucks47_59/t47_121.htmlIf you look close the individual bearings have two prices. One price is domestic and the other is "import". At least they tell you up front! The link Bart posted to Speedway the kit was $95. Check shipping cost! 52Carl.... they are suppose to be an exact fit but over the past few years, and from a post I recently made here, it seems that "some" have had to "sand/polish" the spindles a little but it apparently is not a big deal. Maybe someone got a set of bearing that were close to the "no-go" gauge but still passed the QC check. Unfortunately I have not changed mine but they are laying on my work bench as the next project! | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Alvin and Bart thanks for the info. I paid $47.00 for the one wheel outer with tax. I will order one of these kits and place it on the shelf . Just installed new shoes on front. Next change or wheel packing mine will be changed. Thanks guys | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I got the complete tapered roller set, from CPP 3 years ago for my 55 2nd. They fit and work perfectly. I think they were $78 back then. | | |
