9 members (Hotrod Lincoln, 55shaker, JoergK., Guitplayer, Bill Hanlon, 1955 1 Series, 32Fordpuchoptop, Youngin' Tut 59, 1 invisible), 112 guests, and 1 robot.
Topics128,193
Posts1,057,360
Members48,469
I'm having problems bolting up the drivers side inner fender to the cab at the toeboard the hole will not line up no way no how.
The cab is a chevy and the inners are GMC - anyone ever have this problem?
Has the cab had any sheet-metal work done? Are you sure you have the right size inner fenders? Chebby and GMC should be the same.
1954 GMC De Luxe COE
There is a bracket that bolts to the cab first and the inner fender bolts to that, it's for the e-brake mounting. Is it on there?
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Quote
Hummm that 1 part that missing, can someone please take a picture of what is suppose to look like. I'm building this truck 1 piece at a time.
efi-diy, here is a picture that kind of gives you the idea. Right now my cab is bare and I can take another couple pictures for you if you want. Its under Misc. Pictures.
Good Luck.
COlin
BINGO!
Now I just need to find that part..... anyone have a spare?
Colin,
thanks for the pix !
I can't remember if it just bolts off or not, but I have one I could remove for you. PM me.
Colin
Colin,
Email sent..
thanks
Just a note here about that bracket. If you have a four speed with the hand brake lever on the transmission, the bracket is smaller and doesn't extend down to the rocker panel.
1951 1 Ton Completed
