2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#1200418 01/19/2017 3:50 PM
So I have rebuilt my hydrovac with a rebuild kit from Cadillac parts and now I have no vacuum assist, so obviously I must have put something back in incorrectly. Does anyone have any advice on how to troubleshoot these units? I would like to know where I should be looking rather than a total disassembly.
3B Offline
Hy Jaredm, do you have any brake pedal at all? Does your engine run correctly?
Brake pedal is hard and brakes work fine other than having to push as hard as possible. Engine runs and idles great. Any ideas of where to check would be much appreciated
Crusing in the Passing Lane
No vacuum assist, so, check your vacuum system.
Ed
3B Offline
Hy Jaredm, as EdPruss said you don't appear to have vacuum assist or your atmosphere line air filter or line are plugged. Try removing the rubber hose from the 1/2" pipe on the front of the Hydrovac and trying the brakes again, if they still don't feel boosted then you may have a vacuum supply problem or a leak although you say the engine is running as it should. The other thing may be that the atmosphere valve is not opening which could be an assembly problem, good luck, hope that helps.
I have vacuum at the hydrovac, I will look at the atmosphere valve, maybe I have it in backwards or something.
