3 members (3B, 55shaker, Gdads51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | I find a need to have a small, safe, portable gas supply that is easy to hook up. I often run across vehicles with old stinky gas in their tanks and would like to be able to hear and engine run with fresh gas. Is anyone aware of an existing product or has anyone modified something like a regular gas can or fuel tank from a lawnmower for this purpose? Thanks, Jim | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Boat gas tanks work well for this purpose. They are easily sealed and have provisions for fuel hose.
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Plus many come with a priming bulb.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Ditto on the boat tank. I have used them in demolition derbies, very safe. | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Thanks for the replies! Boat tanks are being considered and will probably end up as my choice. I was thinking about a smaller tank, if possible, a gallon or less is fine for my needs. I got to thinking about this the last time I used my Honda generator. It has a nifty cap that is sealed when the generator is not in use and vented, by turning the fitting on the top of the cap, when it is. Maybe a modified generator or lawnmower tank would work. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I use an old Toro push mower tank...holds about one gallon. It's small enough to hang from the hood to gravity feed the carburetor. Mike B  | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Thanks Mike! That sounds like what I need. And I do happen to have an old mower that was on its way to a recycler. Guess he'll get it without the tank. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Some boat tanks have a screw on cap that includes the hand primer pump, might be able to use the tank cap/pump with any old tank.
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No mods, no special tank, safe, inexpensive, easy to hook up: I use a new style, red, plastic, 2-3 gallon gas container. 3-4 foot of fuel hose. Attach to pump inlet, stick other end down in the not full container. Mini glue clamp holds hose at right depth. It's that easy. Lawn mower tank too small. Don't want a metal one. Don't like hanging gas over me or motor. The plastic one sits on the ground. Any motor's fuel pump will suck gas up in 10 seconds. Take it for a short ride if you need to, with the container in a milk crate on passenger floor, hose thru a hole in firewall. Use the spout that comes with container to pour unused gas back into your own truck. Once you buy the truck and get it home, you will eventually need to go get gas for it. Guess what you use for that. You will need to re-hose truck in places. Guess what you use for that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | For an old vehicle with questionable fuel tank and fuel pump. I use a one gallon pump up weed sprayer. Make sure the gas tank is disconnected from the fuel pump and then clamp in the pump sprayer directly to the carb. Do Not Pump the sprayer very much! It may blow gas past the needle valve, flood the engine and leak gas out on the exhaust manifold.
Also have a heavy rag and fire extinguisher, just in case something does not go as planned.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We use a 10# Freon bottle that has been converted to a pressure tank. Have a 0-10# regulator on wall to cover anything with a carburetor and a 0-165# (compressor limit) regulator to cover most fuel injection units. With this set up we have almost infinite pressure settings to dial in what works best and then use that info to buy a pump/regulator. Learned the hard way about going by what the repair manuals say. IIRC 4 cam Ford engines were supposed to be at 27#'s idle and 44#'s WOT but instead need 61#'s to properly atomize the fuel mixture. Probably too exotic for a home shop but if Don used one of those 2-3#, been around forever, pot metal fuel regulators on his weed sprayer it might work pretty good. Darn sure does away with rusty tank/fuel line/rotting hoses.
Evan
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Great ideas everyone! You guys make Stovebolt the best! Thanks, Jim | | |
