1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
Am looking for a center carrier bearing cushion for my 50 GMC 1-Ton. 253. That's the big rubber isolator donut between the carrier bearing and the bearing housing. Anyone have a source? Jim Carter says the 3/4 ton cushions they have wont fit.
Thanks in advance.
Pete.
You can't run with the big dogs, if you pee like a puppy.
1950 GMC 253 1 Ton
1965 Sunbeam Alpine / 2.8L V6
06 Dodge/Cummins
Offline
Offline
Butyl windshield sealer. Cures flexible. If you leave it in the truck, remove the crumblies and all grease, dirt and oil. Make 8 wood wedges about 4 inches long, one inch wide and 1 inch on the thick end. Add a thin smear of grease to the sides of each wedge. Just enough to say some is on there. Insert wedges by the pair, front and rear, opposing each other. Move them toward each other to attain the proper distance. Place in 4 positions to center the bearing in the housing.
Apply the butyl to the rubber surfaces with a gloved finger, pressing and smearing the butyl on to the rubber with some considerable effort. Now fill that particular cavity with butyl. You may need some tape on each side to keep it in place.
Out of the truck, lay it on something that it won't stick to, and make whatever blocks you need to center everything. Apply as mentioned above.
Do NOT use RTV! Or latex caulk for that matter!
Of course, this is ONLY if you aren't able to find one anywhere.
The last time I bought a center support bearing, it came with the whole cage, bracket and all.
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Thanks for the info. I may have found one on eBay and ordered it this eve. Looks to be the correct part number from the master parts catalog. I'll know next week when it gets here.
Will take you your suggestion if this doesn't pan out.
Pete.
1950 GMC 253 1 Ton
06 Dodge/Cummins
Moderated by  Dusty53
