8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe),
338
Mod | | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Anyone have a trick for removing these that are stuck. Lots of Kroil and lots of time already. Most of them came loose with a big chisel that I can get a big crescent wrench on for torque, but a couple aint givin' up. Didn't fire the torch up yet, that's next.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Feb 2004 Posts: 29,870 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | There's a special 1/2" drive socket- - - - -usually called a "drag link socket" although those are actually a little bigger to fit the larger slot in the drag link. I see them on Evil-bay sometimes, and the tool trucks like Snap-On or MAC can special order them.
Just looked- - - -dozens of 'em on Ebay- - - -pretty reasonable prices, too. Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Thanks Jerry. That's what I needed. One ordered.
| | | | | Joined: Feb 2004 Posts: 29,870 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | I used to keep a few around the shop and custom grind a slightly oversize one to as close a fit in the slot as possible. It helps to have a good fit on the rusty, stubborn ones. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | And use an impact wrench, if possible, need to adequately secure first.
Ed
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I had this problem, I had a rebuild kit complete with a new plug. I drilled a series of holes across the groove and it came out easily in two pieces. | | | | | Joined: Apr 2012 Posts: 12 New Guy | | New Guy Joined: Apr 2012 Posts: 12 | Mine were the same way. Soaked for days with p-fluid and no movement. I finally put some heat to it and they broke loose. | | |
