0 members (), 166 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,471
I know this has been covered before, but Im curious what is needed to bag a stock 51 truck on original frame?
please post pics, and say what you bought etc.
thank you fellas
It aint a hobby it's a lifestyle!
LIFERS C.C.
H Online: Content
It requires a REALLY big sack, and lift carefully so it doesn't tear. "Paper or plastic?"
HiPo Shop forum not general truck talk. Jerry, maybe one of those big green bags you see at construction sites?
My only comment is why? Do not count me among the leg pullers.
I've never done this to a truck,but if you google airbag a 1947-1954 chevy truck, you'll have some reading to do.
looks like ecklers has a kit to do it. air bag kit
Good luck with your project,post some pictures after you slamm your truck.
1951 3100 Chevrolet
hilarious
LIFERS C.C.
Hope you know we are just pulling your leg. I've never seen one bagged with original suspension. Usually ifs and 4 link.
" . . . what is needed to bag a stock 51 truck on original frame . . . "
I tried to bag (and label) all my parts, but after my move from NY to NC, I am still looking for all the boxes with those labelled bags. I needed a few hundred bags. Use permanent ink markers - clearly/completely label the bags with indelible ink markers.
(sorry)
H Online: Content
They wanted to sell me a passenger's side airbag. I told 'em I've had as passenger's side windbag for years!
thanks for all the help guys
LIFERS C.C.
You're probably not going to find what you'r looking for here.
Try this site. The Projects and Builds section is a good place to look.
http://www.67-72chevytrucks.com/vboard/forumdisplay.php?f=13
The Suspension section is good place too. Mostly later model truck, though. There's a good thread going called, "Make it handle." Lots of good setup info there.
http://www.67-72chevytrucks.com/vboard/forumdisplay.php?f=25
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
"The Fake Truck"
Sorry, juspassinthru,
If you find the info you need on bagging a 47-55 1/2 ton truck with original frame, and you undertake the project, please post your progress report here.
It would be interesting to see the "end-product" and a driveability report. I do not recall anyone posting the outcome of such a project.
I can't find a picture of mine installed but here are the brackets I made for my 2 ton for front air springs, I'm using them as helper springs.
https://goo.gl/photos/x8uvet8NAVJCW32KA
They bolt in using the original holes for bump stops and the bags I chose have an internal bump stop.
I'm using a front axle with an additional 2" of drop and custom springs with 2" of lift to get back to normal, this also helps make room for the air helper springs.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
H Online: Content
That's probably because the vast majority of those projects never make it to the road. They either get scrapped, or wrecked pretty soon because the handling is so lousy. Trailer them to the car show and haul 'em home again so they don't become a road hazard for the rest of the driving public.
I agree, Jerry
But, if someone has successfully bagged and tagged (registered with inspection) an A-D truck, that would be interesting to see.
H Online: Content
I saw a relatively late model Dodge Charger last Friday, sitting in a parking lot with the rocker panels literally touching the ground. It also had a "For Sale" sign on it. I wonder why?
Forgot that I have rear air bags on my 2 ton as well, guess that makes it fully bagged?? wink
https://goo.gl/photos/rFojva5bnQRGDE188
Anyhow, Tim I do have it registered, insured, tag on it, and I've driven it on the road some. Definitely not anything related to the air bags keeping me from driving it more often, it's the body that's the problem, not even close to finished.
---All pictures---
H Online: Content
Good-looking setup, Grigg! Just one problem- - - -how are you gonna "lay frame" like the lowriders do, with the frame ABOVE the axle?! !! ! ! !
LOL!
Yes, Grigg, is yours called a lowrider, with duallies, like this one ?
Here's a beauty, but it is not a big truck.
Ahhhh, now here's a big one.
How low can you go, Grigg (that's the cool-factor question)?
...How low can you go, Grigg (that's the cool-factor question)?
I'd have to get out the yardstick... I was hoping for nothing lower than stock. Isn't stock cool too?
---All pictures---
Cool enough for me.
Even bagged low-riders can look cool.
Some readers envisioned a bagged, adjustable-height, low-rider, using the original frame (original frame, like yours, as requested in first post).
everyone is entitled to their opinion I have had several air ride equipped daily drivers.As for the reason why??
its adjustable! making all driving conditions possible.stock height AD trucks handle horrible in every way, body roll in turns and look goofy as [censored] with the fenderwell gaps even with 16" wheels.
To each their own, some folks like bone stock trucks.I prefer mine a bit lower than that.I could care less about laying frame
LIFERS C.C.
"That's probably because the vast majority of those projects never make it to the road."
10,000+ daily driven air-ride miles so far..... grin
I'll be honest it's not been without its problems,actually caused by a crappy installation of both front and rear set-ups in the first place.....(not by me I might add)
More pix on Flickr.
Crusing in the Passing Lane
I bagged the rear of my '37 GMC 2 ton for a better ride, used 2 bags off a Kenworth 4 bag system.
Ed
Look up these guys they do it all the time her in Cali.https://www.facebook.com/teagardenmuffler/
I never have understood pan dragers .in the 70s we hated low riders mainly because they had all our batteries in there trunk.
1937 Chevy 1/2 ton panel
Each to their own and all that...
I run a 4 way air ride on my '50.
It's not a pan dragger but can get down pretty low ,this is it at ride height.
The road conditions here are pretty rural at best but the air-ride does make things a bit more tolerable,I'd have NO teeth left if it was still on leaf springs..... grin
More pix on Flickr.
Jockbolter- Is that a Jeep rearend in your truck?
"The Fake Truck"
No Sir,it's a Borg Warner 'metric' unit from a Gen-3 Firebird.
It was a swap meet special but thankfully the I.D. tag was still attached to one of the diff cover bolts.
It's 3.27:1 ratio with Posi and as you've probably seen,disc brakes.
If you saw my Flickr pics I have also changed out the bespoke diagonal 4 link to a parallel one from Dannys Original Customs in Ca.
The diagonal link wasn't very well done and caused some serious pucker moments while driving at speed!
Strangely the axle with the cast iron calipers have one leading and one trailing so there has been some interference issues with the parking brake arm on the left hand side.
With the new four link the axle mounts foul the actuator arm for the left hand parking brake which is the trailing one.
Although i've noticed the ones with alloy calipers both lead,so will try and find some to convert it when funds and time allow.
Frankly it's a little tired too (a bit clunky when selecting gears) but a rebuild kit for this particular one seems to be also the most expensive and elusive,at least here in Blighty.
More pix on Flickr.
