3 members (Otto Skorzeny, Ponchogl, treegrower), 73 guests, and 3 robots.
Topics128,099
Posts1,056,508
Members48,448
Hi All,
I am reassembling my 1950 ½ ton and I cannot seem to get the pedal accelerator rod and the carbareto linkage to connect. I am pretty sure I am using the hardware I took off the engine but previous I was using a 216 and now I am using a 235.
The original accelerator pedal rod had a single long radius curve. The end now does not match up with the pivoting bracket that links to the carburetor. I searched the internet looking for pictures but all the pedal rods seemed to be “S” shaped.
Do I have to change the pedal rod to use a 235 engine in my truck? Does anyone have pictures of what the proper set up should look like? I should also mention I was running a 1939 216in if that makes a difference.
Skipper
If I remember correctly there are two different holes for the pivot on the block, you may have it in a different position than it was in on the 216.
Tommy
59 apache 1/2t
261 short stepside
Maybe your answer is here on Dave's blog. Throttle Linkage
1951 1 Ton Completed
I ran into the same thing when I was installing a 235 where a 216 used to be. You have to use a 235 connecting rod. It's longer and shaped correctly. The 216 Rod will not Work..... I tried.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
I have used 216 linkage many times on 235 swaps without cutting anything up.
There are a number of variables with this...
My Blog
