| | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I am reassembling my 1950 ½ ton and I cannot seem to get the pedal accelerator rod and the carbareto linkage to connect. I am pretty sure I am using the hardware I took off the engine but previous I was using a 216 and now I am using a 235. The original accelerator pedal rod had a single long radius curve. The end now does not match up with the pivoting bracket that links to the carburetor. I searched the internet looking for pictures but all the pedal rods seemed to be “S” shaped. Do I have to change the pedal rod to use a 235 engine in my truck? Does anyone have pictures of what the proper set up should look like? I should also mention I was running a 1939 216in if that makes a difference. Thanks, Skipper
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If I remember correctly there are two different holes for the pivot on the block, you may have it in a different position than it was in on the 216.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Maybe your answer is here on Dave's blog. Throttle Linkage | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I ran into the same thing when I was installing a 235 where a 216 used to be. You have to use a 235 connecting rod. It's longer and shaped correctly. The 216 Rod will not Work..... I tried.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have used 216 linkage many times on 235 swaps without cutting anything up. There are a number of variables with this...
See the USA in your vintage Chevrolet! My Blog | | |
