2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Does anyone offer or have directions for wooden stake side for the 1941 Chevrolet. I have redone the bed in oak and would like to build oak stakes sides. Thanks
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I slapped together some stake sides for my '50 to use to haul a tall load. I made mine out of 2x4 lumber for the sides and 2x2's for the stakes. You could alsu us 1x4's or 1x6's for the slats. There is no reason you couldn't do the same thing with your truck using better lumber. The best way to proceed in order to get the sides to come out level and true to the bed rails is to insert the stakes into the pockets before you build the rest of the sides. None of my stake pockets seem to be exactly the same depth so leave them a bit long and trim them once the sides are fit. To keep them from rattling, use small cedar wedges. Avoid making the wood press fit into the stake pockets because it will swell with moisture and stick or pop the spot welds. Use a square to make them perpendicular to the sides, and screw the side boards to them with stainless or brass screws. I cut my side boards so they were the same length as the bed rails and mounted them 6" above the bed rails. I wish I would have mounted them lower. They look ok but stuff tends to get between them. It looks better if you leave the top ends of the stakes a bit proud of the top of the side boards and cut them into a point. Amazingly they look pretty good even made out of weathered fir. They kind of complete the look of the truck.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Thanks so much for your ideas and for your encouragement. May the Chevy's god's bless you.
| | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Try this site: http://haist-usa.com/artdecotrucks/identification.htm and scroll down to the bottom of the page. this will give you the correct dimensions for the stake bed.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Oops...I think I mis read the question. Your wanting stake sides not a stake bed. Sorry for the mix-up.
