1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1199293 01/11/2017 4:47 PM
I picked up a 261 block yesterday and was surprised when I decoded it. I'm pretty sure that they were available in 2WD trucks until 1962 and 4WD (K series) until 1963. I've also heard that GM made replacement blocks through 1964.
The one I picked up yesterday decodes to a December 6, 1966 casting date with L66 stamped on the block. The casting code is 3769925. It has the dowel for the oil filter consistent with 1959 and later 261's, so I know the last 6 in the date code does not stand for 1956. There is no serial number on the flat by the distributor, indicating a replacement block.
Pictures attached.
http://s844.photobucket.com/user/ma...2443_zps1ecpla6u.jpg.html?sort=3&o=2
Sharing for a couple reasons that I thought others might find interesting. One is the late date code, much later than the final 1964 casting date that has been previously reported on Stovebolt. Second, notice the clock that is cast into the block by the date code. From what I have researched, GM began to add these to identify not only the assembly conveyor and the date, but the shift and hour of the casting. Never seen the clock on a 'bolt before.
The engine is locked up. It sat open to the elements for many years with the head removed. I hope to be able to save it, but I'm not sure about this one. Even though I live in the dry Arizona desert, we do get a little rain. After I blew all the desert sand out of the open cylinders, I wire brushed the tops of the two high pistons. They are marked .060 over, so there isn't much room left on this one if the rust is very deep. It is sitting in a corner of the garage with Marvel Mystery Oil poured into the cylinders. Fingers crossed...
Matt
Maybellene #1199321 01/11/2017 9:53 PM
Interesting indeed. Did GM manufacture any of these outside the US perhaps? Like maybe down in Brazil or Mexico? Canada?
1950 4100 - unrestored and driven weekly for almost no reason at all.
Maybellene #1199327 01/11/2017 10:34 PM
I think a member once reported (maybe here or on the oldGMCtrucks website) a replacement cast in the late 60s.
An Internet search found a reference to the 261 being made/used in South America through 1986
Maybellene #1199339 01/11/2017 11:58 PM
The Pontiac had a chevrolet 261 in them in Canada. I don't know what years they were available.
1951 3100 Chevrolet
Maybellene #1199344 01/12/2017 12:43 AM
I do not know how long the 261 was put in Canadian trucks, but the Canadian 261 car engine (with hydraulic lifters) was supposedly used in Pontiacs through 1962.
261 engine info - Wikipedia
http://www.canadianponcho.activeboard.com/t30605692/235-vs-261-6-cylinder/
Maybellene #1199362 01/12/2017 2:53 AM
Someone who was working on a Canadian 261 posted a couple months ago that his engine did not have the moveable dowel. I don't know if that is like the USA ones that didn't have the dowel until 1959 or if all of them didn't have the dowel.
Maybellene #1199417 01/12/2017 6:51 PM
Leo Offline
Moderator
Moderator
My uncle worked at the McKinnon plant in St Catharines Ontario where the 261s were made. I've noticed that the Canadian blocks had a M with a square around it cast into it. I don't think they were made beyond 1962 either, but I'm no authority on the matter.
Maybellene #1199442 01/12/2017 10:02 PM
There was a Brazilian version of a suburban that utilized a 261 in 1964....
