1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Have two Carter YF2100S carbs. On the main body fin, one says D27 2100S, and the other says D97 2100S. Anyone know what the codes are for D27 & D97?
1951 Chevy 3100 5-window 261 cu in, 348 Head, Split Fenton Exhaust Offy with Dual Weber 2 Bbl Carbs
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Read the carter information here in carbking's website: http://www.thecarburetorshop.com/Carburetor_ID.htmI don't see anything there that answers your question. Sounds like engineering changes would be denoted with a letter after the "S." As in 2100S__. Carbking knows best and might reply here eventually. I've got a 2101s I will take a look at to see if I can find a similar number.
1951 3100
