0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11989 02/07/2003 1:21 AM | Joined: Feb 2003 Posts: 1 Junior Member | | Junior Member Joined: Feb 2003 Posts: 1 | Has anyone tried to swap out a 206 ('34 Master Coup) to a 235? What fits and what doesn't? Any suggestions? I downloaded the 216 to 235 but can't find anything on the 206. Help! | | |
#11990 02/07/2003 5:08 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The swap can be done: 1. The 235 is about a 1 1/2" shorter than the 206 so you will need to make a plate to move the front mount back. 2. The rear of the 235 has a different bolt pattern so you will need a bell housing from a 37 to 47 truck which will fit the 235 engine and the 34 trans. and will also accept the 34 mounts. 3. You will need a flywheel from a 42 to 54 pass. or truck if you use a 6 volt starter, or 55 to 62 if you use a 12 volt starter(55 to 59 truck use foot start). Use clutch parts including clutch fork from a 1938 or later( they will need to match flywheel clutch size). 4. The exhaust is center dump on a 235 and rear dump on a 206 but that should be an easy fix. 5. You will need a starter from a 38 to 54 if you use a 6 volt flywheel or 55 to 59 truck if you want 12 volts and foot start. 6.You will also need the front bearing retainer from a 38-47 truck 4 speed to accept the later throw out bearing.
See the USA in your vintage Chevrolet! My Blog | | |
#11991 02/07/2003 6:32 PM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Ken,
I posted the same basic message as yours last month (1-21-03) and received some really helpful responses from folks on this forum. You may want to scroll back through the forum pages and read what folks wrote there. I was looking to do the same swap, only my vehicle is a 1935 1 1/2 ton. I've pretty much decided after learning the details of making such a swap to stick with the 206. Best of luck with your project.
John Larson Hoquiam, Wash. 1935 Chevrolet 1.5-ton 1963 Oldsmobile Dynamic 88 2-door 1965 **** F-250 1980 "Honda-Davidson" CB-750 Custom 1989 BMW 325i Convertible (wife's car)
