| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Need advice,I am told that the rear fenders ,that you do not put welting between bed and fender.Some people tell me you do.Anyone know what is right THANKS DON | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I personally DON'T put it on the rear only the front, It's all personal preferance. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Mr. Giant,
The AD's rear fenders left the factory with the fender welting. I personally like the looks of it and it also keeps the fenders from sqeaking against the bed. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mr. Giant,
My understanding is the same as stated in the Jim Carter catalog: Advance-Design front fenters had fender welt from the factory and rear fenders did not have fender welt (on AD and later trucks). However, I do not understand why it was not used - my bet is that anyone who ever removed rear fenders in the last 50+ years put the fenders back on with beaded fender welt.
Tim | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | When I took my 54 apart and I believe it to have been original, there was no seal between rear fenders and bedsides. I will probably install welting at paint time. The front fenders had a gasket type seal but no bead such as what is on the welting. I think those that install welting remove the bead at the point where fender would interfere with hood sides anyway if that description makes any sense. I have not found anyone that sells those seals. Only the fender to inner fender seals are listed as far as I have seen. | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Thanks guys, I think I will put the welting in THANKS DON | | |
