| | | Forums66 Topics128,060 Posts1,055,840 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I am considering going back to my stock steering wheel on my 64. I want to paint it the body color of the truck or black. Do i need to use a special paint of some kind? | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | I've painted a steering wheel and used automotive paint. As a matter of fact I chose not to even use primer to keep the film thickness down. Dupont Chroma One worked quite well. Just make sure the wheel is super clean and scuffed up. Single stage paints really hate contaminants.
Joe | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Also heard JB Weld works well. Never used but will have to do mine eventually. Keep us posted on progress. Good Luck Dan | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If you want it black, appliance enamel in a rattle can might be a good choice. It might even make a good sealer for the hard rubber, you could then scuff it and paint over it. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Before you paint the wheel spray it with "bull dog" it is a paint adhesion promoter that you use on things like plastic bumpers etc... in addition to or instead of a flex agent.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | What was your process on cracks? Did you v out? What type primer/topcoat? Does the oil in your hands effect? I'm not ready to do yet but these are some of the problems I've heard of
Dan | | |
