1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I am going to buy a new wiring harness. What harness should I buy? The better ? Would be who do I buy it from? I see that Jim carter has a harness but not sure if it has turn signals and headlight harness included. I tryed to call today but they were closed. See chevy of the 40's has a harness that the turn signals are included , but looks like the head light harness is extra. Can anyone lead me in the right direction. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I purchased one from rebel wire. Customer service has been great so far and it has been easier then I thought.
Chris | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Are you wanting a modern harness or a cloth covered replica of the original?
| | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi just finished my 46 after many years at the restoration.I got the pvc coated generator with signal lights from chevys of the 40s,I was very pleased with the quality and ease of installation. It's pretty much plug and play.all wire cut to length. However it is a little different from the way the wiring was done originally but everything works. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Are you wanting a modern harness or a cloth covered replica of the original? Are you wanting a modern harness or a cloth covered replica of the original? Modern and a 12 volt system for alternator | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Hi just finished my 46 after many years at the restoration.I got the pvc coated generator with signal lights from chevys of the 40s,I was very pleased with the quality and ease of installation. It's pretty much plug and play.all wire cut to length. However it is a little different from the way the wiring was done originally but everything works. I see they offer a 12 volt system for a alternator.thats what I am wanting. Did it come with the head light harness? Was it complete? That is one of the harnesses I was looking at | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | I think it came with everything except for the heater fan wiring which I ordered separately but mine was a 6 volt and can't say if the 12 volt would be the same. If in doubt of what your getting I would call before ordering | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | metal shaper,
I just finished installing my wiring harness, that I purchased from Y n Z's. It was a cloth replica of the original harness. The only difference, I wanted turn signals incorporated into the harness. It was very easy to install. My only issue was that I had taken the old one out 16 years ago. So, my memory was a little fuzzy, when it came to routing. Any questions I did have, the guys at Y n Z's were more than happy to answer for me. I have learned that just because it is the cheapest, it doesn't mean it is a better deal. I would recommend their product and their service to anybody that would like a recommendation. Good luck with your project and restoration.
Rugo
Steve Rugg 53 3100
