2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1198752 01/07/2017 6:32 PM
Am putting correct Intake/exhaust on my 235 and a Rochester 1B carb. Which rebuild kit would you want? Ethanol resistant or regular. I can get Ethanol free gas for now, but how long will it be available. Thank you for your input...Bill
I'd get ethanol resistant - you never know when/where you might need gas in a place with ethanol-containing gas.
Who carries ethanol resistant kits?
Carburetion specialist
Carl - all of ours are ethanol-resistant; some are ethanol-proof (leather accelerator pumps).
Jon.
The Carburetor Shop
Jon: Do you have a website for your stuff?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
Hey Jon, how about ethanol-proof for Carter YF2100 accelerator pump diaphragm?
Carl, believe me, I have tried!!!!!
Unfortunately, neopreme is an "approved" material for use with ethanol (by our government). Thus the companies that produce the diaphragms have no interest in going with a better material.
Buna N rubber with embedded fiberglass threads is a better material. Unfortunately, to date, I have found no USA supplier that makes the Buna N in a standard thickness for use in the diaphragms. The Buna N manufacturers WILL do a special run, but the cost is just plain astronomical. Perhaps it could be made offshore, but I think most on this forum know my feelings about offshore parts. As long as I own my company, there will be NO offshore parts in my kits.
And even if a special run of the Buna N were made, do not know the exact required thickness. The diaphragm is molded with a steam die, and it would take someone more conversant than me with shrinkage/stretch factors to get it right the first time.
51Bowtie - this forum, like most forums allows each user to display a profile. Clicking on the username for any user will allow access to that information that particular user has provided.
Jon.
The Carburetor Shop
Thanks Jon! I get about 2 years on a diaphragm before it gets stiff and develops a pinhole in it and starts running a little rough, followed by running too rich to idle soon after. I am able to get home by pulling out the throttle cable to boost the RPM high enough to burn the excess fuel. (You gotta love these "antiquated" designs). I keep an extra ready-to-go YF2100 on the shelf just for such emergencies to keep my down time at a minimum.
I am willing to put up with this deal so that I can enjoy the better fuel mileage and performance compared to Model Bs I have run in the past.
Carl
