4 members (Gdads51, Joe H, Otto Skorzeny, Gray_Ghost), 99 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#1198627 01/06/2017 9:57 PM
I am starting my first project and have a 46 1/2 ton with a 235 out of a 53 Bel Air. I'm working on the cooling system and have discovered that the connections are different sizes and am having difficulty finding replacement hoses. Both upper and lower connections on the radiator measure 1.5 in, but the water pump measures 1.25 in and the thermostat housing measures 1 in. I'm not sure what to use, should I try to find some tapered hoses or am I thinking about it too much. The old hoses are ~13 inches long and appear to be the same diameter on each end and just tightened down to the smaller diameter on the engine with hose clamps. Any help / reference would be helpful.
Thanks!
tneely76 #1198632 01/06/2017 10:40 PM
Your local parts store will have access to hoses with different sizes on each end. Find the oldest guy in the place and explain what you need.
tneely76 #1198633 01/06/2017 10:44 PM
I don't have a specific detailed answer, however one of my recent projects was installing a 90's Ford HO 5.0 in my 1990 Miata. The local Napa and O'Reilly stores let me go behind the counter many times to search their inventory first hand for oddball hoses.
Wouldn't hurt to ask, all they can say is no.
RonR
1970 340 Duster
1964 CJ5
tneely76 #1198754 01/07/2017 7:19 PM
I had the same problem on my 46. I talked the counter guy at my local FLAPS to let me search through their assortment of hoses until I found one that worked. You might have to get one longer than you need and cut it down.
George
