Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (60steve, J Lucas, klhansen, greenie-reddy, NJC, TooMany2count, Lightholder's Dad), 130 guests, and 2 robots.
Topics128,277
Posts1,058,451
Members48,490
#1198335 01/05/2017 3:32 AM
I'm not sure where this should go but I have run into a 59 32 series half ton long bed and the vin on the cab and frame check as such but it has a 36 series 8 lug front hub and rear full floating axle. I can't seem to find anywhere where this may have been an option. The only other code on the plate is 5000 lbs GVW and RPO 431YG it also has a 283
Does anyone have an idea if this is a special build or just a swap at the dealer or PO may have done it
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
thoroco #1198383 01/05/2017 4:33 PM
It's hard to tell the 3200 from the 3600 as the sheet metal and frames are the same.
Your 3200 serial number starts as V3B59.
If it's a 3600 it will be V3E59.
The 3200 has either 7 or 8 rear leaf springs, while the 3600 has 9 or 10. Other than the axles that's about the only difference.
I'm not aware of any RPO putting 3/4 ton axles under a 1/2 ton truck, why would they do that???
So, you either have swapped axles or a missed stamped series in your serial number (B should have been an E) from the factory...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
thoroco #1198399 01/05/2017 6:27 PM
I have verified the VIN as 3B59S both on cab and on frame.
With the brake kits we manufacture I have come across many different combinations that were not in the manual or heritage packets. I have seen AD 3600's with factory dual rear wheels and a standard 8 lug front hub and also with a the extended front hub that were not swaps that's why I asked. Could it have been swapped at some point in its life, maybe but as you asked Why? I've seen single wheel trucks with dually axles so I know they did some odd factory installs, Civil defense trucks and forest service trucks sometimes have these upgrades between 36 and 38's but I have not seen one on a 32 before.
I did find in my data book that there was a 5000 lb GVW package that required suspension special ordered separately. This GVW tag says 5000 lbs. It had 8 leaf single stage springs rear 1550 lbs, 1350 lb. Payload (3/4 Ton) and 17.5 inch wheels which I believe were all 8 lug. So this looks like a legit up fit from the factory just very odd.
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
thoroco #1198401 01/05/2017 6:42 PM
Sounds like everything is pointing towards it being a 3200 with swapped axles...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
thoroco #1198404 01/05/2017 6:54 PM
possibly but I'm thinking not unless its a dealer swap, I do know they did have an option for a 32 with those axles according to my salesman's data book for 1959.
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
thoroco #1198494 01/06/2017 3:14 AM
I did a little more research and I don't see the 8-lug floating axle as an option for the 3200.
I do see the HD rear springs (8 leaf) with 7x17.5 tires which would raise the GVW to 5000 pounds, but those 17.5 rims are 6-lug p/n 3724684, the 17.5 8-lug rims are p/n 3724683.
The difference in GVW between the 3200HD and the 3600 standard is only 200 pounds (5000 vs 5200).
The 3200 cost $1,986.00 + 125.50 (7x17.5 tires) = $2,111.50.
The 3600 cost $2,132.00 (with Std 17.5 tires).
Why would anyone buy a HD 1/2 ton when you could get the standard 3/4 ton for $20 more?
I still believe your axles were installed outside the factory.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
