3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1185779 10/07/2016 2:41 AM
Has anyone had experience with the Stovebolt "Mini" HEI for 292 offered by Langdon's Stovebolt?
Tom B
1953 Chevy 3/4 ton 3600
1964 292 cu. in. in-line six
Tom B #1185800 10/07/2016 4:33 AM
I've run one of his 235 HEI distributor for several years & no problems. Unless you are set on the small size G.M. used HEI on those engines from '75 up.
BC
1960 C60 pasture art
Tom B #1185809 10/07/2016 5:57 AM
Because of the location of the AC compressor, the small size is the only one that will fit in my application.
Tom B
Tom B #1185810 10/07/2016 6:11 AM
In that case, yes I'd go with one of Langdons.
BC
Tom B #1185811 10/07/2016 6:23 AM
We in fact did that and we're having difficulty keeping it timed. Didn't know if anyone else was having the same issue. The folks at Langdon's will return to their office on 10 October and I'm expecting to hear from them shortly thereafter.
Tom B
Tom B #1197989 01/02/2017 10:33 PM
I too am having timing problems with Langdons "mini" HEI any help would be greatly appreciated Thanks Jerry
Thank you,
Jerry's Body Shop #52
[email protected]
816-833-4414
Tom B #1198076 01/03/2017 3:58 PM
In case you didn't know, GM used a short cap HEI with the coil remotely mounted. It maybe something to look into.
Tom B #1198095 01/03/2017 5:52 PM
Joe, do you have an application or part #s? Thanks Jerry
Thank you,
[email protected]
816-833-4414
Tom B #1198149 01/04/2017 3:25 AM
https://www.napaonline.com/napa/en/p/MPERR192SB/MPERR192SB_0223600857
https://www.napaonline.com/napa/en/p/ECHIC22/ECHIC22_0238732818
Above are the parts from NAPA, you may find them at any parts store. I used a 1976 Chevrolet C10 pickup with 250ci engine.
This is the only picture I could find of a stock distributor. As you can see it has a longer wire harness to reach the remote mounted coil. http://www.ebay.com/itm/DISTRIBUTOR-6-250-4-1L-FITS-75-76-CAMARO-6467-/262745815456?fits=Make%3AChevrolet
This shows the end of the harness very clearly,
http://www.ebay.com/itm/1977-Chevrolet-GMC-250-292-4-1-4-8-Brand-NEW-Distributor-Lifetime-Warranty-/391624368051?fits=Make%3AChevrolet
If the e-bay links get deleted, just search for " Chevrolet 250 distributor "
Joe
Tom B #1198178 01/04/2017 6:14 AM
Y
yar Offline
Y Offline
Tom,
On Chevy Talk High Performance Topics there is a frequent poster with the handle Ignition Man who is very knowledgeable on this subject:
http://www.chevytalk.org/fusionbb/showforum.php?fid/72/keyword/Chevy_Performance/
He knows which of the aftermarket distributors work and which to avoid. He also builds custom HEI distributors.
Ray
Tom B #1198199 01/04/2017 1:53 PM
Crusing in the Passing Lane
I have used a large cap on my 302, just have to rotate it to fit. When getting one in a wrecking yard, inspect it carefully, all the terminals on the cap must be evenly spaced, odd fire Buick V6 caps will not work.
Ed
Tom B #1198280 01/04/2017 10:01 PM
Thanks guys I have a lot to discuss with my customer Jerry
Thank you,
[email protected]
816-833-4414
Tom B #1201944 01/29/2017 12:37 AM
As a quick follow-up on my experience with Langdon's small HEI, Tom L. responded to my phone call. He gave me five troubleshooting steps to follow. When those steps did not solve the problem, I sent the HEI to him. He repaired the "reluctor" and returned it to me. So far the engine starts under both hot and cold conditions. We will be giving it some extensive run time in the near future.
Tom B
