0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Can I put 1948 1/2 ton fenders on a big bolt cab or is the cowel larger? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If it is a regular cab (not a COE), the half ton cab is identical to the big truck cab, other than maybe the transmission cover plate.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | That's what I wanted to hear! Thanks. | | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | You might want to check out the "Big Bolts" board, been discussed. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You can bolt them on to the cab but all the sheet metal in the front will probably not work with them. By big bolt here, I am assuming you mean that it has the larger wheel openings. | | |
