| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | The panels behind my front wheels are rusted through. It was that way when I bought it. It has been in the garage since I've had it. By keeping it completely dry will that inhibit further rusting at all or will it continue with the same vengence as it would outside? I know I'll eventually need to replace those panels & cut out rust in other places but don't want to spend the time on the rust, yet. Thank.
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Rance, keeping it completely dry will stop the rust, and if it's gonna stay in the garage there's no need to put the rust repair at the top of the list
Bill | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | most rusting starts from the underside where mud ans trash is trapped and not washed clean so unless you clean the underside where the wet material is you will get more rust...doc | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Thorough cleaning of all dirt and debris, followed by a coat of rust neutralizer/converter/encapsulator, will inhibit the rust from encroaching. Good luck with your project. | | |
