| | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | hey gang. my 61 apache 235, 3 on the tree. putting in sbc v8 and sagina 4speed(car 4 speed) I have a v8 bell housing with pass side clutch, I want to run disk brakes up front. if I go with new master cylinder for the disk, what happens to the clutch resivior? what have you guys dun? I don't wana do the zbar thing if I can help it.
1961 apache
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Use a clutch master cylinder for a mid-1960's Dodge pickup. You'll probably have to offset the clutch M/C mounting and modify the pedal linkage if you use a vacuum booster for the disc brakes. Jerry
