| | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | Good Day Stove Bolters'
I am currently working on the rear springs of my biggy and I believe they have been modified. Would anybody out there have a good photo of what their stock springs look like (if there are any out there)
Kregus Lakewood, CO
1946 2 Ton (I think)
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Kregus, Welcome to the Stovebolt.
I will try to get some photo's of one of mine tomorrow. Why do you think they have been modified? Could you post up some photo's of yours? There are a lot of springs there, but I can't remember how many. I have a 40 1 1/2 ton GMC, a 41 2-ton, a 46 2-ton chassis and a restored 46 2-ton. The springs are very similar on all of them.
| | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | I will get a couple of photos up in the next couple of days.
I have the riveted brackets still mounted to them but the bolt holes that span the leafs look like there are 2 leafs missing, according to everything I have read I have the right quantity of leafs.
Thank you
Kregus Lakewood, CO
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One might want to consider the types of loads that will be carried. Most of our trucks are way over sprung for the use we put them to, giving a much harsher ride than necessary.
Ed
Kregus Lakewood, CO
| | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | Kregus,
Looking at your pictures, I believe that your springs have indeed been modified. The thick spacer plate is definitely an addition, and it maybe replacing a thinner "leaf". It also appears that several of the leaves have been re-arched. I'll try to remember to look at my truck tomorrow and grab a couple of pictures, but off the top of my head I think there are 18 leaves in the rear spring packs. I know all of the leaves in my spring pack are the same thickness, and that there are two "groups" of springs (the main set are all together and have the same arch, and the "overload" set also have a similar arch but are separated from the main by a couple of fairly short leaves.
I went through my photos and found the two best shots I currently have of my rear springs and put them in my signature gallery. They don't show quite enough detail to get you what you need but maybe they will help. | | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | Thank You for your help.
Nice looking truck by the way
Kregus Lakewood, CO
| | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | Ok, I took a few photos of the rear springs and added them to my signature gallery. Should be more helpful than the ones that were on there before. | | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | Thank You 2ton46,that confirms what I thought and gives me the path to make it right
Kregus Lakewood, CO
