| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 35 | I've decided to finally pull the trigger on a set of 19.5" wheels for my '48 (I already have tires I received in a trade a while ago) as I am getting tired of putting air in the front right tire every weekend. Does anyone have a source for clamping plates? Accuride recommends GM P/N: 472536 but I can't seem to find them anywhere.
Aaron V. 1948 Chevrolet 3800 216/4-spd 1979 Chevrolet C30 Ramp Truck 454/TH-400 1995 Jeep Cherokee 4.0/5-spd 1970 Ford F100 390/4-spd 1973 Ford Maverick 302/C4 2004 Honda Shadow 1100
"While driving yesterday I saw a banana peel in the road and instinctively swerved to avoid it᠁thanks Mario Kart."
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They're freely discarded in junk yards, I've collected several sets when removing wheels from trucks and just laying around. This is probably by far the cheapest too.
Can you use your old original clamping plates, I did on my GMC with newer 19.5 wheels, nothing wrong with that. | | | | | Joined: Apr 2016 Posts: 3 New Guy | | New Guy Joined: Apr 2016 Posts: 3 | I just went through this. I upgraded to 5/8 studs with the accuride wheels. (new for front and outer on back, and then old wheels on back inner to fit around brake hub. Instead of clamping plates I went with swivel nuts from lug nut king on ebay. I think they look great. I powder coated all the wheels a classic white. I upgraded the studs as the accuride wheels have a 5/8 stud hole. I can give you part numbers if you want. front inner wheel seal was the hardest for me to find. 1962 P30 is the same size from rockauto. I did a lot of measuring for the studs, but finally picked some parts from Dorman | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have used swivel or flange lug nuts before and I've gone back to clamping plates where the wheel manufacturer recommends them. I think they do a better job supporting and stiffening the center of the wheel. They also look more appropriate when that's what the truck came with to start with.
Grigg | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | There's quite a few Wheel Clamp Rings GM # 472536 on ebay......go to ebay & type in the search box.....472536 . Photo @ photobucket http://i669.photobucket.com/albums/...lamp_%20GM%20_%20472536__zpsjqhde1wb.jpgGM part # 472536 is available GM NOS @ 1.) Friesen's Chevrolet Sutton, Nebraska phone: 402-773-5538 Friesen's has ( 1 ) - GM # 472536 in stock 2.) Sea Coast Chevrolet Ocean, NJ phone: 732-918-1100 Sea Coast has ( 1 ) - GM # 472536 in stock 3.) Chuck Hutton's Chevrolet Memphis, TENN phone: 901-369-0719 Hutton's has ( 1 ) - GM # 472536 in stock 4.) Chicago Auto Parts Saint Anne, ILL phone: 815-614-3122 Chicago has ( 1 ) - GM # 472536 in stock George '54 3600 | | |
