| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 6 New Guy | | New Guy Joined: Nov 2012 Posts: 6 | Hi bolters, here is Simon from Québec city, Canada,i ve just buy 1934 chevy 1.5 ton found in a barn here in the province of Québec, it was abandonned in the early 1960. the cab is solid, sheetmetal near perfect,the old 207 engine runs and the truck is in a remarquable shape in comparaison that we found normally here in Québec. its a model build here in Canada at the Oshawa plant called the maple leaf trucks, i c ant found any inscription or nameplate, just the plate: 10500 gross weight, 3450weight i c ant decode the v.i.n. plate with U.S. built decoding tables, anyone knows canadian-built early chevrolets ? very merry Christmas and happy new year ! Simon | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hi Simon, 3B out in Chilliwack knows a lot more than I do, he may even have one. I thought that Maple Leaf trucks were heavier than 1.5 tons. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ten, Maple Leaf trucks were 2 1/2 ton and Three ton trucks. In 1939 and newer the three ton trucks were powered by GMC full precision bearinged engines. The 1600 series trucks were the 2 1/2 ton trucks and the 1700 series were the 3 tons, hope that helps. | | | | | Joined: Nov 2012 Posts: 6 New Guy | | New Guy Joined: Nov 2012 Posts: 6 | thanks, the model is 118X, trim 99,serial 629764, paint 1426 (red in color with black fenders)body serial 852, engine t4386256 if these numbers means something... thanks for your interest ! | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Try here for some info Canadian trucks looks like '34 is mmissing, but near years may help? Sorry but my books start at '48. Good luck and congratulations though! | | |
