5 members (jmoore, klhansen, GA Boy, fonz8261, 1 invisible), 99 guests, and 4 robots.
Topics128,179
Posts1,057,138
Members48,463
Two engine stands a little steel some welding and primer. Frame now has 2 coats epoxy primer and hopefully some gloss black paint if I get lucky today
Dan
http://community.webshots.com/mypho...=2951450480071274430&security=qeOjmO
That really looks good.Let me know when the show is in Norwich.We can get together and discuss early 40's trucks.
The crew that works on the \'42 --Sara, Hannah and Abby
Great Idea Dan. I think I will fab one of those frame flippers myself. I knew there was good justification for having two engine stands :p
Chris Simmonds
1942 Chevy 3/4 ton
Got the gloss on yesterday......Would have been a lot better if I used black primer. Was hard to cover wherever frame had crossmembers. Will do fine for now. It feels like I'm starting to make progress after 2 years.
Dan
http://community.webshots.com/mypho...=2443607920071274430&security=qOhWVQ
Junior Member
Junior Member
Well done Dan. I'll try that. Did you find they had a tendency to roll or tip as you changed the position of the frame?
Allan S Langley B.C Canada
Capt Al,
Flipper was sound and easy to use I was very happy. I had to build up the engine stands to completely roll the frame. I needed about 2-4 inches to completely roll frame. It was quite solid even built up. I ended up placing a pallet underneath to raise. It made working/painting a lot easier than expected
Dan
